Tire Loading How To???
   / Tire Loading How To??? #1
crabjoe
Ceciltucky, MD
Kioti CK20S HST
Is there such a thing on this site or maybe somewhere else?
I picked up a bunch of Washer fluid and a fitting to connect a hose to the tire valve. Now I just need to know how to get the fluid in there.
Common sense and what I've found here tells me I need get the weight off the tire (Jack), take the stem out and connect the adapter. After that is where I'm a little confused.
I'm guessing what I need to do is now connect the hose to a funnel and pour the fluid in. It's either that or get a hand pump, that can connect to a hose. And being that I have no idea where to get a cheap pump, will the funnel work without breaking my back and making my arms fall off, trying to hold it up?
Thanks!!
johnk said:
I picked up one of these units @ TSC last year but haven't put it to use yet..This should be what you are looking for.
Air/Liquid Tire Adapter Set M8846 by Victor Automotive | DoItYourself.com
I've got one of those, but my big concern is getting the fluid into the tire. I just can't see myself hold a funnel, for hours, to let gravity do it's thing.
Over on the Kioti forum, I found a post from a guy saying he used a drill pump. Where does one usually find these things locally, because I'd like to fill my tires before the stone arrives.
   / Tire Loading How To??? #4
Drill pump works good.
soundguy
   / Tire Loading How To??? #5
You should be able to find one at a hardware store "True Value" or Lowes or Home Depot, for example. They chuck up in the drill and you can connect them to a garden hose. On the suction side put a short length of hose into your washer fluid and connect the discharge to your adapter and you should be in business.
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2024 JOHN DEERE 461M LOT NUMBER 60 (A53084)
2024 JOHN DEERE...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
