Tires Tire Inflation procedure
   / Tire Inflation procedure #1
ham1
Hey anybody out there can expalain on how to add pressure to a tire that is low?
It really sounds stupid but it is a liquid filled tire and I though I could get my compressor out and bring it up to normal with that.
When I uncrewed the valve stem cap, and began to put pressure in the tire, liquid began squirting out and I had to put the valvr stem cap back on.
What gives? I know this cant be that difficult. It is a tractor I inherited so I am new to this.
Thanks in advance
   / Tire Inflation procedure #2
The tire should have only about 75% fluid, so check the air pressure with the valve stem positioned above the fluid line from about the 10:00-2:00 position.
   / Tire Inflation procedure #3
It sounds as if you have a bad valve core. Even with the valve stem at the bottom, the core should not leak with the valve cap removed. So, personally, I'd jack it up to take the load off that tire, rotate it so the valve stem is at the top (12 o'clock position), then remove the valve core and replace it. Then add the air to it.
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
UNUSED TOPCAT QUICK ATTACH TREE SHEAR (A51244)
UNUSED TOPCAT...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2018 FORD F-550 (A50323)
2018 FORD F-550...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
