bmark
I am currently running turf tires on the rear and R4 tires on the front of my New Holland 1925D and my dealer has told me that I need to go with all of one type because the R4 fronts are a different size than the Turfs. Anyone else had any problems with mixing types? Also, my dealer stated that I needed to put fluid in my rears because otherwise, the loader puts too much strain on the front axle. That doesn't make sense to me, how can adding weight to the rear tires take strain off the fron axle? Now if he had said add balast on the drawbar, I can understand since that would cause a weight transfer to from the front to the back.
I am considering fluid to give me more stability via a lower center of gravity and for that reason, thought 50% fill would be better than 75% since I'm keeping the added weight below the axle. What is the conventional thinking?
Lastly, I have a steep asphalt drive and have had some traction issues when blading snow, but am afraid of tearing up the asphalt if I go to chains. Do chains tend to eat up the asphalt or not?
Thanks,
Mark
Thanks,
Mark
