Tire chains-what works best for you?
   / Tire chains-what works best for you? #1
JonBarleycorn
WNC
Kubota L4330
I am now researching a set of rear chains, and have looked at tirechains.com thusfar. I get the impression from their site that ladder chains are not best for deep tread tires as in my NEW tires. I have considered the duo-grip and double ring.
What have you used and has it served you well?
Also, anyone buy from tractor chains from this outfit?
I bought a set of v-bars for my truck some years ago, and they are not the worst and not the best.
I found it interesting to note they also stated certain models of chains would damage pavement. Well, yeh....they are chains, and chains do that. Better to scratch the pavement than slide into the house.
BTW, primary use will be on steep, gravel road and secondary on level stamped concrete for snow/ice removal.
   / Tire chains-what works best for you? #2
I got and installed the duo grip v bar chains for the back of my CK30 ag treads, no snow yet, just been driving them around on gravel and dirt, they stay above the treads. Some ladder chains (car) I had I put on the front and they have gone down inside the treads, can't see they would do any good.
These rear ones seem like they are pretty hefty and will work well, but no snow/ice experience yet.
65lbs each!
Mike
   / Tire chains-what works best for you? #3
Jon -- I guess it sort of depends on your terrain and your type and amount of snow. I have a steep dirt road and driveways, bitter cold (-30) early in the winter and sloppy cold (25 to 35) late in the winter. Plenty of ice and snow ranging from light and fluffy to wet and very heavy. In my experience double ring are great in wet sloppy stuff or mud, but not on ice. For ice, the best IMO is a chain that gives you a continuous contact with the ground.
I use Valby ice spikes (attachment) but the current generation is a lot lighter and easier to handle at 120# per side than the 300# per side monsters I had on the L3010. So far, I've not noticed any decrease in grip.
Ice is tough. You need something that has edges if you want any significant grip. V-bars and ice spikes come to mind. The duo-grip and double rings just don't have the edges you need.
Pete
   / Tire chains-what works best for you? #4
It sounds like you have ag tires. You need a chain set that will stand above the tire lugs, or cross over them to actually bite. If so, you can't use my setup, truck chains on turf tires, which works great.
   / Tire chains-what works best for you? #5
Does anyone know if a "quick attach" chain that would work well on my JD 4520 with R4 tires exists? I have strongly thought about buying a set but cannot find what I need. I have very little clearance between my tire and fender well, and the tires are loaded, which means they weigh about 450# each. I would not use chains much (three-four times yearly) but I think they would help stopping on some of the big hills I have. I just need some that will mount pretty quickly and would hold up to 2-3 hours four times yearly on a tractor this heavy. I looked on most popular sites, but cannot tell by the pix which, if any, is the correct choice.
John M
   / Tire chains-what works best for you? #7
</font><font color="blue" class="small">( Does anyone know if a "quick attach" chain that would work well on my JD 4520 with R4 tires exists? I have strongly thought about buying a set but cannot find what I need. I have very little clearance between my tire and fender well, and the tires are loaded, which means they weigh about 450# each. I would not use chains much (three-four times yearly) but I think they would help stopping on some of the big hills I have. I just need some that will mount pretty quickly and would hold up to 2-3 hours four times yearly on a tractor this heavy. I looked on most popular sites, but cannot tell by the pix which, if any, is the correct choice.
John M )</font>
I purchased chains for my TC40DA and you can read about it here. I got them from tirechains.com and they took me about 20 minutes each to put on the first time. Since I got them on, we have had above normal temps, so haven't been able to try them out.
I laid the chains out behind the tractor and backed up until there was a couple inches of chain in front of the tires. Then I hung the chain over the tire. Not easy with the fender design and the heavy chain, but doable. Hook up was easy - just an S-hook on the inside and the adjustable hook on the outside.
I did take a drive around the barnyard and drove up a steep embankment without a problem. They will stay on top of the tread.
Bottom line is I don't know if I would want to put/take off lots of times, but it is certainly doable.
   / Tire chains-what works best for you? #8
There is a lot easyer way to put any style chain on than the way you did it. Try it this way. Lay the chain out behind the tractor the way it will lay on the tire. Take a piece of 1/4" rope about 6 feet long and at the first cross link tie one end of the rope to the center of the first cross link. Then tie a big enough loop to fit over the tire tread and loop it over. Then drive the tractor forward and it will pull the chain right onto the tire. Just be sure to check that the chain is maintaining its pattern when it goes up and over the tire. I am in my mid 60's and if I had to manhandle mine they would never get put on.
   / Tire chains-what works best for you? #9
Deerlope -- I do it pretty much the same but use a heavy duty bungee cord. The lugs on my ags are big enough that they hold the bungee. When I back over the chain the bungee cord pulls it right up the tire.
Pete
   / Tire chains-what works best for you? #10
Wow, wish I had posted earlier /forums/images/graemlins/tongue.gif! Thanks for the tips. I love reading this board. I'm always learning something.
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
1263 (A50490)
1263 (A50490)
2019 JOHN DEERE 8245R LOT NUMBER 187 (A53084)
2019 JOHN DEERE...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
