Efis
- Joined
- Aug 2, 2013
- Messages
- 16
- Location
- Northwest Colorado
- Tractor
- Allmand 35D(tlb535),Gravely pro 16,5665
Sorry for the late reply. I have an allmand 35d, similar design to terramite. Just bought it in November so I am new to it. I got it for summertime business but have been testing it out this winter moving snow. I have been impressed by how well it does especially for 2wd. I think the relatively large amount of weight over the rear wheels and the limited slip axel helps it to perform quite well in snow. It is the largest model of the 2wds and weighs close to 5000#. I played around with it in the yard building sledding ramps for the kids with and with out chains in a couple feet of snow never felt close to being stuck. Moderate slopes but mostly had advantage of going up. I do have 5 gallon bucket of gravel in rear bucket for extra weight. The chains Definitely help a lot. Mine are left over from past vehicles, the rear are regular 4 link ladders so on the less aggressive side. I believe I bought them off the shelf at Walmart. The fronts have lighter weight ladder style chains with lugs and they definately help with steering more so on slick packed surface than deep loose. I think a different pattern than ladders would help on the front. Sometimes in loose slow and not enough weight on the front tires the chains will work like a sled runner and steer in the opposite direction. Maybe a diamond pattern would help, I ve thought of attaching chain running around the circumference to act like a ribbed tire. Hard to say if its doable without knowing exactly what all the variables are in your situation. One nice thing about a tlb is you can get yourself out of a lot of situations with the hoe and loader. Sounds like it would be fun to find out. Do you have a way to tow it out if need be? Hope this helps.
