suntreemcanic
My B7800 does not have clearance for tire chains. Does anyone know of 1 inch spacers that I could install between hub and wheel for chain clearance?
No, you do not have to do that. At least the ones I bought (and I'm pretty sure other brands) are designed such that the original studs or lug bolts are used to hold the spacers on and then the wheels are fastened to the spacers using bolts that they supply. Very neat and well designed.You probably will have to install lengthened bolts/studs for any spacers, but once you do, if you only want an inch, just get some large nuts, 1" thick, and use them as spacers. Not pretty, but will work. I put 2" Kubota spacers on my tractor for stability, mostly when pushing a plow. I really don't use the plow anymore, knock on wood. PS: also helped with chains... something else I don't need to use anymore.
