Tire blowout - long
   / Tire blowout - long #13
Tally,
Next time you haul hay take your lucky yanmar key chain with you.
Ring the little bell while walking around your trailer, get in the truck and burn the road up, you're covered.:rolleyes:
Oh Yea its on the way!
Ern.
   / Tire blowout - long #14
tractorErnie said:
Tally, Next time you haul hay take your lucky yanmar key chain with you. Ring the little bell while walking around your trailer, get in the truck and burn the road up, you're covered.:rolleyes: Oh Yea its on the way! Ern.
I'm willing to try anything right now!:eek:
THANKS!!!!!!!!
   / Tire blowout - long #15
tallyho8 said:
You can't stop on the Causeway so I slowed to 35 mph and drove the remaining 4 miles off the bridge and pulled over to change the tire. Luckily the other wheel on that side bore the weight and everything went well. .
I would seriously consider replacing the second tire on that side. It was probably overloaded and while it may look OK you can anticipate another blowout soon.
   / Tire blowout - long #16
tallyho8 said:
IT GOT ME---AGAIN!!!
Someone is trying to tell you something. Time wise, I'd go the safer route with your luck on that causeway.
-Mike Z.
   / Tire blowout - long #17
Man Tally, what luck.
At least it did not come out worse, but good greif, what else could you have done?
I think there must be a little troll with a handful of caltrops just looking for you to come across. :)
1838 (A51248)
1838 (A51248)
2016 Dodge Caravan Van (A55758)
2016 Dodge Caravan...
40' CONTAINER (A54757)
Fiberglass Cow Statue (A55218)
Fiberglass Cow...
TAKEUCHI TL10 SKID STEER (A52705)
TAKEUCHI TL10 SKID...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
