Tire Bead Breaker
/ Tire Bead Breaker #1
ETpilot
East Texas
I got a flat tire on my lowboy trailer. The problem turned out to be an old leaking tubeless tire valve. To change it out I had to break the bead. I made this simple device to do the work. I cut a short 2x6 for the compression piece and used a 2x2 for the actuation lever. I cut a dado in the lever to fit the angle iron on the trailer and clamped a stop block for the compression piece. I set the lever at a 10-15* angle. It worked real nice.
I also decided to clean and paint the old rim. Looks good now.
The down side is that the 2x2 is not strong enough. Once I got the outside bead broken, I tried the inside bead and broke the lever. A 2x4 on edge would have been stronger but I did not have one handy.
I am going to experiment with this and may make one out of steel with an exhangeable foot for the different rims. I will see. I am going to put balancing beads in my truck tires so I will try this on my truck tires and see how it works.
Thought I'd post FWIW.
/ Tire Bead Breaker
I used to do the same thing with a 2x4 until safety beads came along. I suspect that this is a very old rim without a safety bead, can't quite tell by the pictures. It looks to be an old Mopar rim. The safety bead rims are pretty rough to do without a machine or special tool.
Well, you learn something new everyday. I have never heard of safety beads. I have come across some hard to break beads before but never heard nor read the term before. I did a quick search to find out more. I definitely will look into these safety beads.
The trailer is pretty old so it may not have safety beads. Any idea when they came out with this feature?
/ Tire Bead Breaker #3
I just replaced a valve stem on my wifes vehicle a couple days ago. Seems she got too close to a curb and the long valve stem hit it and got bent enough to crack it and it was leaking slow. I took the tire off and put it on the cement apron of the garage, removed the valve stem core, put a 2x6 on the edge of the tire close to the rim and drove my truck up the 2x6. The tire bead separated and I was able to replace the valve assy and reinflate it.
/ Tire Bead Breaker #5
I've simply used a jack under the truck receiver hitch to break beads...
/ Tire Bead Breaker #6
I use my FEL to push down on it but after battling with quite a few I now just take it to the tire shop and give the guy $10. I may pick up one of them bead breakers from HF, I hear good things about it.
Chris
/ Tire Bead Breaker
Well, today I learned a little bit about safety beads. The rim on the trailer did have the safety bead. It appears to be a standard feature on tubeless rims. The safety bead is pressed into the rim just in front of the tire valve and goes full circle around the rim. This makes a hump on the inside of the rim. The hump helps hold the tire bead against the outside flange. When you fill the tire with air, it makes a pop when the bead jumps the hump and pops into place.
I checked all my equipment today and all have the safety bead. I could not tell on the truck and jeep as they have fancier rims and you cannot tell. I did check some old rims that I use as the base for tool stands. They did not have the safety bead. It was all flat metal to the well of the rim.
Very interesting. I am glad I started this thread. I learned something.
Now, I am going to fabricate a better bead breaker.
/ Tire Bead Breaker #11
I use high lift jack under the front bumper of my jeep. Works every time, but bead braker would be nice.
And do you know how to seat it without a compressor? I done it many times before I got a pressured air in my shop.
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
SKID STEER MOUNTING PLATE (A60432)
SKID STEER...
UNUSED IRANCH MINI EXCAVATOR RAKE (A60432)
UNUSED IRANCH MINI...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
