Ballast Tire ballast types
   / Tire ballast types #1
491ton
Milton, Iowa
John Deere 3320 cab tractor
What different fluids can be used for ballast?
   / Tire ballast types #2
RV antifreeze, windshield wiper fluid, calcium chloride solution, beet juice (rimguard), and probably maple syrup or anything else that won't freeze where you live. So probably Jack Daniels too.
   / Tire ballast types #3
What's in yours? Where is it parked?
   / Tire ballast types #4
LOL,--- Jack Daniels as well---
but watch out for the pot heads as they will siphon it and you'll find your tractor with 2 flats!
   / Tire ballast types #5
At about $100 / gallon, Jack would not be my first choice for tire ballast but, it is my first choice for Rick ballast. ;-)
Sent from my iPad using TractorByNet
   / Tire ballast types #6
Why would a pot head steal whiskey from your tractor tires?
   / Tire ballast types #7
Nor should a siphon be necessary. Just a core tool and a pint cup.
   / Tire ballast types #8
Both my tractor's tires are filled with calcium. Good to go down to minus 40 degrees.
Never a single problem,exept for a leaking valve corroding the rim.
All those tires have a inner tube.
In my opinionm ballast is a must for serious tractor work. Traction and balance beeing part of the equation.
   / Tire ballast types #9
Methanol aka Methyl Alcohol is also a common fill. Usually mixed with water to some degree. Methanol is the active anti-freeze ingredient in Windshield Washer Fluid.
   / Tire ballast types #10
Has anyone ever tried a dry material like sand or even lead shot? It would be hard to get inside but seems like it would work well.
I'm sure someone has tried it.
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
WIGGINS 5K FORKLIFT (A52472)
WIGGINS 5K...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2008 D&P WELDING  18FT 2000 GAL FUEL TRAILER (A52472)
2008 D&P WELDING...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
