Ballast tire ballast in subcompact tractor
   / tire ballast in subcompact tractor #21
You don't want calcium chloride or salt for ballast if your tires are tubeless or it will rust the rims real quick I would either use rimguard or another non corrosive liquid for ballast to be safe and also you will need to use a tire pressure guage that is made for checking the tire pressure on fluid filled tires .
BUT;
If you add inner tubes you can!
   / tire ballast in subcompact tractor #22
Well I had a hard time finding pure CaCL- the hardware store has 92% CaCL, and the rest is NaCl and other stuff. I got tired of researching so called a few shops, and did find one that can do the beet juice. I dropped the tires off this afternoon, and will get them back tomorrow for the grand total of $86. I could hardly buy the CaCL for that, so it was far cheaper than I had thought.
Thanks for all the suggestions- I'll feel better not putting in the salt-water.
Next up- modifying a quick-hitch to give me a place to place suitcase weights. :)
While I figure that one out, I pulled apart the SCV linkage- it's sloppy and worn. Maybe they should have put zerts on those pieces- all dried out, no lube left at all. I can replace the worn parts for $200, which seams pretty steep.
Any ideas on how to turn down the shafts and re-bush it?
   / tire ballast in subcompact tractor #23
I just did my first 50 hour service on my GC2310TLB. To my suprise when removing one rear tire I found it to be liquid filled (and really, really heavy...). I am still not sure if it came that way from the factory or if my dealer did it.
   / tire ballast in subcompact tractor #24
not sure if you can rebuild it with bushin and turn old pin. Can you go the next size up and add zerks ? you might have to drill out the hole for new larger pin ( i know i know i would hate to do the same thing) . I am not sure of the size of your old pin so its kinda hard to tell from pics.
   / tire ballast in subcompact tractor #25
...and at the other end of that spectrum, I did my 50 hour service this summer and was surprised at how very light it was - and since then have debated about filling it. I've thought the added weight would help when using the backhoe.
   / tire ballast in subcompact tractor #26
Think you'll be very ahppy with the rimguard. My only regret was waiting 8 years before doing it. Makes a work of difference, more stable on slopes and when doing loader work and MUCH better traction when doing dirt work, laoder work, or snow work.
   / tire ballast in subcompact tractor #27
I've not measured the pins, but one is about 3/8" and the other a little bigger. I put it all back together with some grease for now. No more squeaks at least.
I thought about zerks too- but I bet if I just greased it once a year, I'd be fine. This tractor lived outside for four years, so I suspect that didn't help any either.
My filled tires weighed 148 pounds (26x12x12 R4). I forgot to weigh them empty, but they were light. At 10 gallons per tire, and 11# per gallon (according to the Rim Guard site), I added about 220# to the back end.
That ought to be enough to keep the bucket from lifting the rear off the ground when it hits a block of ice.
   / tire ballast in subcompact tractor #28
Well the 200+ pounds in my tires certainly helps, but I need more to move ice in the bucket. I'm going to buy a quick-hitch and weld a cross-member on it, then hang on 4-6 suitcase weights.
Problem with that is that I don't know how to weld yet. :) The local Oxarc shop offers instruction for $25/hr, so I'm going to go down and have them jump-start my learning a little. I'm also watching craigslist for a used mig with enough juice to do 1/4" steel easily.
   / tire ballast in subcompact tractor #29
Why not just have the shop weld a cross member onto your quick hitch for you?
DEWFPO
   / tire ballast in subcompact tractor #30
I got methinal in my rears[alcohol],not as heavy[weighs same as water basicly] but cheap and won't rust your valve stems like calcium,cheaper than the beet juice.
Got it mixed with water at about 1/3 methinal to 2/3 water,got a tire man with a pump and stuff,he came out and was done with it in about an hour.
UNUSED FUTURE SZYMJ HYD MINI STUMP GRINDER (A58376)
UNUSED FUTURE...
2013 Toro Z Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2013 Toro Z Master...
LOT: (6) Office Chairs (A59076)
LOT: (6) Office...
2011 John Deere 855DXUV Gator (A57149)
2011 John Deere...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
