Oil & Fuel Tips\Tricks for Changing Transmission Fluid in CK30
   / Tips\Tricks for Changing Transmission Fluid in CK30 #1
hiker88
belgrade, maine
none
I need to change out the transmission fluid in my CK30 tomorrow and I'm looking for tips on refilling it - got it all drained out this afternoon. Mostly I'm wondering if there is a trick to getting almost 7 and 1/4 gallons of fluid down that 1 inch fill hole without making a mess and taking all day.
I have 1, 5 gallon container, and 3, 1 gallon containers. I was leaning towards starting off with the one gallon containers, and then transferring a gallon from the 5, into one of the 1 gallon containers and repeat as necessary. Trying to pour a funnels worth out of that 5 gallon bucket seems a disaster waiting to happen.
There appears to be a air release bolt on top of the housing so I will remove that, and keep the dip stick out to let air escape, but other than that, looking to see if anyone has any tricks.
Thanks!
   / Tips\Tricks for Changing Transmission Fluid in CK30 #2
good siphon hose works with the 5 gallon container in the drivers seat.
Hey thanks,
I appreciate the help.
   / Tips\Tricks for Changing Transmission Fluid in CK30 #5
   / Tips\Tricks for Changing Transmission Fluid in CK30 #6
Whichever you do, do it slowly. IF the oil decides to burp out the fill hole you will wear it.
   / Tips\Tricks for Changing Transmission Fluid in CK30 #7
I used this one: 5 Gallon Oil Pump
It screws onto the pop-up lip of a 5 gal pail and gets almost all of the oil out of the pail. On mine, the clear hose leaked at both ends from pumping pressure, so I added a couple small hose clamps and all was well.
   / Tips\Tricks for Changing Transmission Fluid in CK30 #8
Ya know, I didn't even see that one, but then again it must have been in the high dollar isle.:eek:
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
Electric Mobility Scooter (A55853)
Electric Mobility...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2016 PETERBILT 579 TANDEM AXLE MID ROOF SLEEPER TRUCK (A54607)
2016 PETERBILT 579...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
