Oil & Fuel Tips\Tricks for Changing Transmission Fluid in CK30
   / Tips\Tricks for Changing Transmission Fluid in CK30 #1
hiker88
Bronze Member
belgrade, maine
none
I need to change out the transmission fluid in my CK30 tomorrow and I'm looking for tips on refilling it - got it all drained out this afternoon. Mostly I'm wondering if there is a trick to getting almost 7 and 1/4 gallons of fluid down that 1 inch fill hole without making a mess and taking all day.
I have 1, 5 gallon container, and 3, 1 gallon containers. I was leaning towards starting off with the one gallon containers, and then transferring a gallon from the 5, into one of the 1 gallon containers and repeat as necessary. Trying to pour a funnels worth out of that 5 gallon bucket seems a disaster waiting to happen.
There appears to be a air release bolt on top of the housing so I will remove that, and keep the dip stick out to let air escape, but other than that, looking to see if anyone has any tricks.
Thanks!
   / Tips\Tricks for Changing Transmission Fluid in CK30 #2
good siphon hose works with the 5 gallon container in the drivers seat.
Hey thanks,
I appreciate the help.
   / Tips\Tricks for Changing Transmission Fluid in CK30 #5
   / Tips\Tricks for Changing Transmission Fluid in CK30 #6
Whichever you do, do it slowly. IF the oil decides to burp out the fill hole you will wear it.
   / Tips\Tricks for Changing Transmission Fluid in CK30 #7
I used this one: 5 Gallon Oil Pump
It screws onto the pop-up lip of a 5 gal pail and gets almost all of the oil out of the pail. On mine, the clear hose leaked at both ends from pumping pressure, so I added a couple small hose clamps and all was well.
   / Tips\Tricks for Changing Transmission Fluid in CK30 #8
Ya know, I didn't even see that one, but then again it must have been in the high dollar isle.:eek:
2019 Doosan LCV6 Towable Light Tower (A51691)
2019 Doosan LCV6...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2016 Ford F-550 4x4 Ext. Cab and Chassis Truck (A50323)
2016 Ford F-550...
Case CX210D Excavator (A50514)
Case CX210D...
