Tips on taking front wheel hub apart???
   / Tips on taking front wheel hub apart??? #1
MiserableOldFart
Platinum Member
Delaware County Catskills NY
NH Workmaster 40, Kubota GR2120
I have a problem in one of my front hubs in TC26DA, at a minimum a shot seal. Won't know more until I get in there. But it doesn't want to come apart, and, unlike other makes I've seen in videos online, there are no "notches" to put a prying tool into. So how do I get it split apart without scoring the faces of the pieces? I assume that it's just permatex holding it together, but I'm afraid of doing damage if I try to get a prying tool in there.
Any help would be appreciated.
OK.. here's a tip for anyone else.. I tried utility knife, putty knife, etc. with no luck. Finally got the idea to try a very old, thin bladed pocket knife I have had for about 40 years, and it was old when given to me. Sharpened it up and it tapped right into the thing and it came apart easily. But now the innards don't seem to match the diagrams I have, so it's more head scratching time..
   / Tips on taking front wheel hub apart??? #3
I'm sorry,
I got so frustrated with trying to post pics on this site. I stopped looking at last week. I could of gave you some tips. But glad you got it done 👍
   / Tips on taking front wheel hub apart??? #4
Pull the inner bearing off the axle stub with a couple rolling head pry bars. Lift the bevel gear off the splined axle. Remove the two halves of the lock ring. Turn the remaining axle, seal, bearing and cover over and drop the inner end of the axle shaft onto a wood block while holding the cover. The axle should come out of the cover , bearing and seal.
   / Tips on taking front wheel hub apart??? #5
Thanks rick. He figured it out and posted on my post
MiserableOldFart MiserableOldFart is offline
MiserableOldFart's Avatar Join DateJun 2006Posts272LocationDelaware County Catskills NYTractorNH TC26DA, Kubota GR2120
Default Re: Fwd wheel bearings replacement
Just finished replacing seal and bearing in my TC26DA. Job is likely very similar. An easy job the second time, but needed some head scratching on this, my first. Trickiest part was getting the case apart which worked easily with an old pocket knife after trying all kinds of things. Unless the stuff is real expensive, I would replace the two bearings and the seal, get a spare snap ring in case the one in there goes flying. Nice to have but not absolute necessity would be as set of seal/bearing driving tools, and a cheap hook type seal yanker. A sturdy workbench near the tractor is good as well.
Now that I've done it once, I don't expect it to be much of a problem in the future. But I would get at it quickly! The innards of my outside bearing had pretty much disintegrated, tearing up the seal (which gave the black oil leak that showed there was a problem) and put a lot of small pieces of metal in the case. Certainly didn't do the gears any good, though they seem OK.
UNUSED FUTURE FT-X39 39" HYD TRENCHER (A57193)
UNUSED FUTURE...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2018 Caterpillar 12M3 (A53317)
2018 Caterpillar...
2025 Swict 84in Bucket Skid Steer Attachment (A55851)
2025 Swict 84in...
UNUSED 1RANCH 1RET13 HIGH END ELECTRIC TRICYCLE (A57192)
UNUSED 1RANCH...
