coollx
Bronze Member
Removed my 46 backhoe from my 2520 today for the first time which was sort of a pita.
Well actually the hardest part was removing the pins holding the front of the frame to the mounting brackets. I kept adjusting the stabilizers and boom to see if the pins would just slip out which they wouldn't so I worked them out with a small pry bar. I see they are tapered so to put them in it might be easiest to tap them in place with a hammer?
For those of you who have had your BH on and off a few times, is there an easy way to remove the pins? Any other BH removal and installation tips you can pass along for us new BH owners?
Thanks for the help
Thanks for the help
