tips for nailing wet wood
   / tips for nailing wet wood #1
rald
East TN
I just finished stacking/stickering my first load of white oak and was wondering how long I should wait before replacing rotted sheathing. I read on old post that it's fine to put up wet wood on a barn provided you use proper nailing techniques. Any details on these nailing tips? Since I am OK with small gaps between the boards (<1/2"), I now understand that I can put this wood up wet. The boards boards are ~1x7s by 10' long.
Ralph
   / tips for nailing wet wood #3
Not sure about nailing but I would keep the boards so the outside (of the tree) is to the weather...
   / tips for nailing wet wood #4
no matter what you do , the boards will warp ... the side exposed to the outside of the barn will dry out quicker and shrink , warping the boards ...
if you must put it up wet , do as above....
   / tips for nailing wet wood #5
Nail gun.
   / tips for nailing wet wood #6
I've built quite a bit with green spruce. I never had trouble with warping, I've used 12", 8", 6", 4" x 1" and 2".. I always use either 2 or three nails across. The sap would spit as you nailed it. If you are doing green, get it up before it starts to dry, before the boards start to twist.
The idea of center nailing green wood I think is misguided. I wouldn't do that.
The boards all shrank, boards side by side could easily shrink to give 3/8 to 1/2" gaps. I always oppose angles in nailing by hand or using a nailing gun.
It is not oak, never used oak for anything - too expensive. Set it aside and use it for flooring, cabinets, paneling, sell it!
Good luck!
   / tips for nailing wet wood #7
I think the board & batten technique was created for green siding. Even as the boards shrink, the gaps are hidden by the battens.
Thanks for the link, tips, and related info.
Ralph
   / tips for nailing wet wood #9
This stuff is really going to pull at the nails when it shrinks. I'd suggest using spiral shank nails and a nail gun.
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2012 INTERNATIONAL DURASTAR 4400 SBA 6X4 WATER TRU (A51247)
2012 INTERNATIONAL...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2014 FORD TAURUS SEL SEDAN (A51247)
2014 FORD TAURUS...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
Reserved (A53117)
Reserved (A53117)
