Tips for FEL level indicator?
   / Tips for FEL level indicator? #11
After some seat time the gray cells take over and you can discard the indicator as looking at it will only interfere with the loader operation!:D :D :D
   / Tips for FEL level indicator? #12
I pushed a short piece of rubber hose over the tube to extend it until it lined up with the end of the rod with the bucket level.
   / Tips for FEL level indicator? #13
Take a file and cut a grove around the rod where the level indication should be. Then paint or use a marker and the indication should be protected from rubbing off.
   / Tips for FEL level indicator? #14
johnk said:
If the rod is sticking out a little while the bucket is level draw a ring around the rod with a magic marker right above the tube instead of cutting the rod. When the black circle meets the tube you're level...
Good Idea.
Like it better than sawing off the rod.
   / Tips for FEL level indicator? #15
You really only need to groove the rod partially, just the portion of the rod visible from the tractor seat, which I think is a bit less than half.
But as someone else mentioned, with experience, most will learn how much rod indicates a level bucket.
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2023 CORAS PREDATOR 28FT DUMP TRAILER (A58018)
2023 CORAS...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
2016 Peterbilt 337 Corrosive Flammable Liquid Transport Truck (A55973)
2016 Peterbilt 337...
