Tips Cutting old Pasture Ground for hay
   / Tips Cutting old Pasture Ground for hay #11
Sounds like you on the right track. I use urea 46-0-0 on the hay pile, but with your pig poo you wont need it. I compost my horse poo by just piling it up and turn it over once in a while. With you situation just start a pile and layer in as this develop - especially the sloppy stuff. Good luck. So far I have been able to use all I produce. I use it to level field ruts - just dump a bucket and back drag so it fills in between the grass clumps. So far it is working well.
   / Tips Cutting old Pasture Ground for hay #12
Thanks @powerscol. I think we are on the same wavelength regards the extra nitrogen. I went on a trip and spoke with a guy who 'does it properly' with a windrow turner and covers and the compost was amazing stuff. He had a heat probe that he'd check the temperature with, if it got up to 68°C then he'd turn it to avoid killing all the biological life in the row. Think that's 155°F. I'm looking for a more stable, slower method as I obviously can't turn 400 cubic yards with my bucket in an hour or 2.. so I thought I'd pick your mind. How high do you build your pile? The downside is that the base in the barn is very coarse woodchip, which will take forever to decompose. I will source finer stuff for next time, that's for sure.
   / Tips Cutting old Pasture Ground for hay #13
Piles are no higher than the bucket can reach - keeps it simple.
INFLATABLE BOAT & TRAILER (A52708)
INFLATABLE BOAT &...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2025 AGT MX-CRT23 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attach... (A59225)
2025 AGT MX-CRT23...
