Tip of the day.
   / Tip of the day.
We go through more than 1 gallon of bar oil per year and that is exactly what we do. That is, take a knife and make a slot cut in the can seal for highly controllable pours. I'll post a pic if I can get one.
Yes, post a pic, the only way I picture it is a slit in the inner foil seal, but that doesn’t seem right.
   / Tip of the day. #42
I use a permanent marker to write the tire pressure on the inside of tire rims. Tractor, Gator (front and back different), 2 double axel trailers, ZTR.... Just cannot remember and hard to read pressure without finding my glasses!
   / Tip of the day. #45
Instead of pull chains for lights in our closets I installed motion sensor lights.
Hate having to find the pull chain in the dark.
   / Tip of the day. #46
Motion sensor switches are great little gadgets. I have one in the bathroom with some under the counter edge lights set for 4 minutes. In the middle of the night I don't have to find the light switch. It turns on when I get out of bed and turns off after I'm back in bed. No more fumbling around in the dark.
I have another in a dark shed. This one is used with a lawnmower 12v battery and a string of LED lights. Been meaning to put a small solar charger on the battery but as it is connected with alligator clips it needs charging about 2 times a yr. 50ft of LED Light up the 10x16 shed pretty good. Again auto on when you open the door and off at your setting 5-15min. Need more time? Wave your arm.
   / Tip of the day. #47
Here is the bar oil jug with a pour slot cut in its foil seal. I see a did a rather poor job cutting on this one! :ROFLMAO:
The other is how we carry bar oil and saw gas into the field when we backpack it in. This a msl fuel bottle which are leak proof since they are a pressure vessel. The oil bottle remains a bar oil bottle.
   / Tip of the day. #48
Sometimes I use an axe or a rock as you have. :p Mostly I prefer to cut a triangle with my pocket knife.
   / Tip of the day. #49
Paint Pens work great for filters and rims also. More permanent than a Sharpie but still comes off with brake cleaner.
   / Tip of the day. #50
Doorbell switch for each garage door opener by each G/D, and the bank of them together at the house door. So nice to walk out the G/D and hit the switch right by it.
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2013 International WorkStar 7400 Altec AM650 50ft Material Handling Insulated Bucket Truck (A55852)
2013 International...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2004 Towable Light Tower (A55851)
2004 Towable Light...
