Tip for hooking up PTO shaft. Drop a dime.
   / Tip for hooking up PTO shaft. Drop a dime. #1
Jelf
Redmond, WA
Kubota L35
Ever feel like you are about to push a hole into your thumb when you are trying to depress that pin far enough to slide the PTO shaft onto the tractor or equipment? Drop a dime into the thumb compartment of your glove. Now your thumb pushes on the dime and the dime pushes on the pin. Gotta love low-tech solutions.
   / Tip for hooking up PTO shaft. Drop a dime. #2
Good idea.:thumbsup:
I guess it's a function of age, but I can't come anywhere near being able to exert pressure with my fingers that I could when I was younger.
Steve
   / Tip for hooking up PTO shaft. Drop a dime. #3
Grease also helps a lot...
   / Tip for hooking up PTO shaft. Drop a dime. #4
I grease mine at the beginning of each season - a heavy coat of grease brushed in with a cheap flux brush. This makes it MUCH easier to mount up, and also makes the pin easier to push in and lock.
   / Tip for hooking up PTO shaft. Drop a dime. #5
I don't wear gloves so would I have to Superglue it to the end of my finger ???:thumbsup:
   / Tip for hooking up PTO shaft. Drop a dime. #6
Great idea. I've never thought of dropping a dime before trying this but on a few occasions I've almost dropped a duece straining so hard to hook up the PTO shaft
   / Tip for hooking up PTO shaft. Drop a dime. #8
Don't forget to sterilize the dime. Those Germs will kill ya!
   / Tip for hooking up PTO shaft. Drop a dime. #9
I tend to use a lot of silicone spray as it doesn't attract dirt and grit like heavy grease can.
   / Tip for hooking up PTO shaft. Drop a dime. #10
Between the GRUNT needed to lift the unattached end, depress the locking pin and rotate the shaft to get engagement - - YOU BET I'm going to give the dime a try, next time.
I have so much grease on the PTO stub and all over and inside the U-joint - - at times it feels like pushing puddin' into a rat hole.
Spirit scooter (A55787)
Spirit scooter...
ALLISON TRANSMISSION (A55745)
ALLISON...
2020 Peterbilt 367 (A55973)
2020 Peterbilt 367...
2006 Caterpillar 315C L Hydraulic Excavator (A56857)
2006 Caterpillar...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55315)
Mahindra 4550-4L...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
