Tiny-tach/Diesel RPMs on a BX23
   / Tiny-tach/Diesel RPMs on a BX23 #1
Speedy7
Bronze Member
North East MA
Kubota BX23
I just installed my Tiny-Tach diesel tach and have a question. In light of all the "fast idle, engine life, etc" debate here, I was curious about my rpms, but puzzled by my BX23 readings.
At the lowest throttle setting, the RPMs show 1280. At the fastest setting, it shows 3390 rpm. Since the BX23 has it's engine and PTO rated at 3200 rpm, I'm inclined to believe the high reading. However, I'm puzzled by the 1280 rpm on the lowest throttle setting. Do these diesels really idle that fast? Maybe I'm not a good judge of a diesel idle, but it doesn't sound as fast as that to me.
Any comments from other tiny-tach owners, or other owners with built in tachs? Thanks!
SP
   / Tiny-tach/Diesel RPMs on a BX23 #2
I have a 2cyl bx.
I checked my idle with an infrared digital tach. It works by counting revs after you stick a little piece of reflective tape on the flywheela and aim the device at the spinning tape. Dead accurate. Mine said 1380, which I believe to be accurate recommended idle speed for the 2 cyl, which is higher than the 3 cyl, due to vibration levels.
FWIW, my top speed was also 100 rpm higher than the rated hp rpm. I think your mini tach is dead on.
   / Tiny-tach/Diesel RPMs on a BX23 #3
Speedy7
Were did you buy the tach.
The only aftermarket diesel tach I could find was at www.tinytach.com. It uses a piezo-electric transducer on the fuel injection line to measure the rpms. $65
Mike L - Thanks for confirming the BX rpms!
   / Tiny-tach/Diesel RPMs on a BX23 #6
I have one on my 2200 and love it.
Gives ya the big tractor feel................
ron
   / Tiny-tach/Diesel RPMs on a BX23 #7
What size of transducer is proper for the BX series? Is it the 1/4" or the 6mm? Is it possible to remove the factory hour meter and flush mount the Tiny-tach?
Not sure about other Kubota models, but on my BX23, you need the 6 mm transducer. The tach is bigger than the hour meter and won't fit in the hour meter slot unless you expand it. I just stuck it on the top of the dashboard with double sided tape.
   / Tiny-tach/Diesel RPMs on a BX23 #10
I have a TinyTach on my BX2200 but I am not as thrilled with it as some of the posters above. My TinyTach started to lose display segments at two years of use. There is no way to repair it so you have to buy a replacement. Also, it has an internal battery that is not replaceable with a life expectancy of five years. After five years you have to buy a new TinyTach.
I think that they should have at least made the battery replaceable.
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
