Rake TINES FOR LANDSCAPE RAKE
/ TINES FOR LANDSCAPE RAKE #1
winchman
western, pa
kubota 2410 with loaded R4s
Does anybody have or, know of a good source for tines?
Has anyone replaced any on their rake? cost? I would like to build a rake of my own and the tines are the only thing that I can't fabricate. I need to know the cost of the tines to see if it would be feasible to build one or, not.
Thanks in advance,
winchman
/ TINES FOR LANDSCAPE RAKE #2
winchman:
Shortly after I bought my Linebach landscape rake I caught one of the tines on a small stump or something and broke it. I went to the dealer I got the rake from and bought a replacement. I don't remember exactly what it cost but I do remember it wasn't cheap (somewhere around $10 maybe) - and that it would certainly cost a bunch to replace them all...
I have also seen rake tines at Farm & Country (now closed).
/ TINES FOR LANDSCAPE RAKE #3
Try http://www.agri-supply.com/catmain/1900042.htm Found them under farm machinery parts, landscape rakes. We have one in Petersburg, VA. Its great. Quite a bit different from the defunct CT and Tractor Supply as they carry a lot of plow and implement parts, trailer axles and hitches, implements plus a lot of just about everything farm related.
Halsey,
I think it is www.ag-supply.com. They have them for $2.99 each. Thanks for the tip. This means that I can build one pretty cheap. Thanks Guys!
winchman
/ TINES FOR LANDSCAPE RAKE #5
Winchman
I had the same idea until I got a few prices on replacement tines. $ ??xx times 36 for a 6 foot rake starts getting expensive.
Most tines I checked on were 5/16 "X 1" cross section so I figured that would be a common size. Then I looked for an old rake for low money just for the tines. I found one in Want Ad book.
9 foot rake real bad shape $50.00 , some tines were bad but there were enough to make a 6 foot rake and have 6 spare tines. The rest of this rake was only good if used for an anchor.
Good luck.
/ TINES FOR LANDSCAPE RAKE #6
Well you get what you pay for I know that york makes a good rake and if you bellie up to the bar it would be the last rake you would buy. York also makes a cheeper rake they call Modern rake but it hase the good teeth on it and you better do a lot of rakeing if you want to wear out a set of these babies
2019 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65056)
2019 CATERPILLAR...
2009 CATERPILLAR CS56 SMOOTH DRUM ROLLER (A65056)
2009 CATERPILLAR...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
Electro Magic Hot Wash Cabinet Parts Washer (A66734)
Electro Magic Hot...
2002 STERLING L7500 SINGLE AXLE BEVERAGE BODY TRUCK (A69167)
2002 STERLING...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
