Tin roof replacement
   / Tin roof replacement #1
Kendrick
Vermont
DK45S(Cab)
I am needing to find a source on tin roof. after 30 min of searching with 0 results on the net i figured id ask to see where one should look.
3 squares have blown off and many many holes. most are just small rust spots sugesstions on all are appriciated
   / Tin roof replacement #2
Just about any lumber yard should be able to get you where you need to be. The yellow book might be a better source this time. I'd turn you on to my sources but Texas is a little far........
   / Tin roof replacement #4
Where in Vt? What is the existing style and are you trying to match?
   / Tin roof replacement #5
Kendrick, I can't see how anything can't be found on the internet in 30 minutes, unless you have dial-up!:D
Every lumber yard in N.E. has metal (steel / aluminum) roofing availible. It's ordered directly from a rolling mill cut to length to the nearest inch. Usually order by specific day one week & delivered the next day the following week, i.e. order by Wed pickup following Thurs. All have brochures listing trim pieces, colors, fasteners & fastening spec, etc. Delivers from PA, Quebec...
If you replace the entire roof you'll be good for about 100 years with occasional maintenence & could sell the used metal you remove quite readily. MikeD74T
   / Tin roof replacement #6
Kendrick said:
I am needing to find a source on tin roof. after 30 min of searching with 0 results on the net i figured id ask to see where one should look. ...
Your lack of finding any TIN roofing may be due to looking for TIN. Very few product actually made from Tin. I'd loook for metal roofing as that would cover both aluminum and steel.
Here is something on TIN from Wikipedia.
"In modern times, the word "tin" is often improperly used as a generic phrase for any silvery metal that comes in sheets. Most everyday materials that are commonly called "tin", such as aluminum foil, beverage cans, corrugated building sheathing and tin cans, are actually made of steel or aluminum, although tin cans (tinned cans) do contain a thin coating of tin to inhibit rust. Likewise, so-called "tin toys" are usually made of steel, and may or may not have a coating of tin to inhibit rust."
   / Tin roof replacement #7
Try doing a search for "metal roofing" and look at what's available. Most barns in our area use what is called 5V.
Here is what one manufacturer has to offer:
Fabral: Light Gauge Agricultural / Wood Frame
As mentioned earlier you can order it cut to length, the last I used I got from the local metal metal roofing dealer and it was ready in 3 days.
The screws hold much better than the nails, IMHO.
Thankyou all for your responses.
My other post didnt seem to have been posted :/
Mike) If you spelled the way i do you would be lucky to find your own name ;)
I can usually find weard stuff but common things I never use the right search phrase
Micky) I did search for steal corigated. found plenty of stuff about elastomers to fix a leaky "tin" roof but never found a place selling the darn stuff its self. i think i even used some of the links from wikopedia to try and find sources cant remember now though.
Randy) agreed with screws and rubber gromets. i may do that for this patch but I dont know. there are hundreds of rustouts. once we get the main house and other parts of the farm going proper we will then be in a position to fully replace the barn roof and probably the whole barn its self. we havent decided how best to tackel the job.
   / Tin roof replacement #10
On a related note...... i need to roof our small barn in the near future. Is there anything available that will replicate an old rusty looking metal barn roof?
UNUSED SWICT 66" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 66"...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
2012 Volkswagen Passat Passenger Car, VIN # 1VWCN7A38CC043906 (A55758)
2012 Volkswagen...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
