timing
   / timing #1
Sprocket 1956
3600 ford
my engine got turned with the injector pump off how do i re-time
   / timing #2
Welcome to TBN!
It is impossible to help you as we do not know what you are working on. Make and model of the tractor will get you a good response.
   / timing #4
Not difficult at all. The timing gear that the injection pump bolts up only one way, so the major timing will be correct. When you bolt the pump to the timing cover, you will line up the scribed mark on the pump ear with the 0 deg mark on the cover. If no mark on the cover, leave the pump slightly loose and move the pump slightly of the middle of the bolt hole until the engine sounds good.
   / timing #5
Those gears are “captured” for the most part.. meaning u gotta try pretty hard to move them..
It’s worth a try to reinstall the pump..
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2010 CHEVROLET SILVERADO (INOPERABLE) (A53843)
2010 CHEVROLET...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
SET OF (6) LADDERS (A53843)
SET OF (6) LADDERS...
1837 (A51248)
1837 (A51248)
