Timing WIndow on L3710
   / Timing WIndow on L3710 #1
Kubota3710
Bronze Member
Northern Alabama
LS XR4046 Kubota G1800
Help!
I am doing the 800 hr service and ready to adjust the valves. The kubota manual does not show the location of the timing window and it doesn't seem to be back in the area of the flywheel.
Could it be covered up with the front end loader frame?
Anyone know where to look?
Thanks, Rich
Ok,
I finally found the timing window, it is behind the front end loader frame. I had to remove the right side of the frame to get access to the timing window.
In case others want to know the tractor had just over 800 hours and values were still pretty close and the tractor still ran smooth. 2 valves were on the tight side, but within limits. 3 other values were loose a few thousandths over the limit. The Kubota values were very easy to adjust.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
Titian Tractor Backhoe (A57454)
Titian Tractor...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
207275 (A52708)
207275 (A52708)
