timing window location
/ timing window location #1
jonsstihl
Quebec, Canada
Hey guys, just getting ready for the 800 hrs valve adjustment on my L4740 Kubota and I can't seem to find the timing window. Unless it is hidden behind the right side loader mount which would just about be the worst place to put it.
workshop manual isn't really clear about its location other than on the clutch housing.
I hope I can get away with only removing the muffler for access but the fuel tank seems awfully close. I just filled the tank up so If it needs to come off I will have to postpone the job.
just scrolled through the engine section of the service manual and it really does look like they put it behind the loader mount on the right side. it is not identified in the picture I saw it in but it looks similar.
anyone done this before and knows if I can get the valve cover off without removing the fuel tank.
/ timing window location #3
Yes, behind the right loader mount.
I usually run (adjust) the valves with the engine running. Dropping the loader arms will make things a lot easier.
Thanks for the reply. Didn't think to look at the parts catalog.
4022CFL (A59228)
4022CFL (A59228)
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
1995 Kenworth W900 Studio Sleeper (A62613)
1995 Kenworth W900...
GYRO-TRAC (A65053)
GYRO-TRAC (A65053)
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
