Timing MF 165
/ Timing MF 165 #1
jacster
72 Massey Ferguson 165
New member in trouble already. I'm about to put a new injector pump on my 70 ish Massey Ferguson 165. Pretty sure the engine is a perkins AD4.203. Isn't the pump located by a dowel in the drive gear and if so won't the timing be correct if I just line up the scribe marks on the new pump the same place they were on the old one? I'm thinking 4 cycle 4 cylinder so they all fire in 2 revolutions of the crank . Doesn't the pump turn one revolution for the crankshafts 2 and fire all 4 in one revolution. Since it is located by a dowel pin in the drive gear it couldn't be installed out of time except by the amount it could move on the 3 mount bolts which the scribe mark on the case should take care of. Can someone straighten me out or tell me if I am thinking right. The reason I'm sweating this is she wears a front end loader that makes it impossible to turn the engine except by the starter or jacking it up and using the wheel. Any help appreciated much.
/ Timing MF 165 #2
Hopefully u have it figured out by now..?? Yes, its doweled & cant get to 180* out of time..
The only way it can get off is IF u removed/moved the gear.. Good luck.
/ Timing MF 165
Many thanks to thepumpguysc for the reply to my plea for help.
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2017 WEILER P265 ASPHALT PAVER (A65053)
2017 WEILER P265...
2012 International WorkStar 7500 Gallbreath T/A Rolloff Truck (A64194)
2012 International...
