Timing marks on 1978 IH684
   / Timing marks on 1978 IH684 #1
Thumbsup
Ireland
I'm new here. I have a 1978 IH684. I want to remove the injector pump. Where are the marks for TDC? Can I find them without opening? Where can I look?
Thanks in anticipation,,,
Thumbsup.
   / Timing marks on 1978 IH684 #2
TDC and timingmarks on frontpulley, use emerytape to clean paint off the pulley
   / Timing marks on 1978 IH684 #3
If you're simply removing the pump for maintenance and not really concerned with the present timing, you really don't need the marks. You can remove the timing window cover plate on the pump, rotate the engine until the marks line up, and remove the pump at that point. When you put the pump back on, rotate the pump housing until the marks are back in register and tighten it down. This will work provided you don't need to turn the engine while the pump is off.
Thanks for your help guys.
Hi Guys.
I found these marks on the pulley of my ih684 and took a picture.
Which mark is TDC.
I * * I I 1 I 0 I I I I 2 I 0 I I I
   / Timing marks on 1978 IH684 #6
where is 20deg BTDC........IN THE MIDDLE OF THE 2 AND 0
............10DEG btdc .........IN THE MIDDLE OF THE 1 AND THE 0
Ihope that this will help finding TDC
Cheers!...Brilliant!
   / Timing marks on 1978 IH684 #8
Engine........D-239........Timing Advance......static timing-engine, degrees BTDC = 16
   / Timing marks on 1978 IH684 #9
Now for the next bit off info.......Open up the pumps window and turn the engine until the marks in the pump line-up .........the check on the frontpulley where the pointer lines up with the timingmarks . If at 16BTDC .........remove the pump........if not.........thats how it should be returned
Thanks DLTTrekkers . Thanks for your keen interest . especially your guidance on reading the timing marks . I.m on the pig's back now. Cheers.
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
1991 TRAILMASTER CRUDE TRAILER (A58214)
1991 TRAILMASTER...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2006 Wells Cargo 16ft T/A Enclosed Cargo Trailer (A55973)
2006 Wells Cargo...
2016 Chevrolet Tahoe SUV (A54815)
2016 Chevrolet...
