Oil & Fuel Timing Jinma 284, LL380 engine
   / Timing Jinma 284, LL380 engine #1
JINMAJK
Sagle, ID
284 JINMA
My First Post Have been learning a lot from other posts.
I messed up let engine oil run low seizing to piston bearings. Pulled engine cleaned aluminiun from bearings with muric acid Looks pretty good.
but when I tried to Pull the crank I forgot about timing. The other gears should be in sink but how do i Line up the crank to the rest.
Jinmajk:confused2:
   / Timing Jinma 284, LL380 engine #2
Welcome. Most all engines have timing marks (little round dots) on the gears. What I usually see is two on the crankshaft and one on the cam shaft, but no idea on you model tractor. On the bikes I work on they all have OHC and you align marks on the cam sprocket with the head or with engine centerline. If no marks, set the crank at #1 TDC and put the camshaft in with the #1 exhaust barely starting to open.
Thanks for the quick responce, I will clean it up today and see what I can find.
Thank you again I'll report what I find.
Jinmajk
Fawken:
Hope the picture shows if it does can you make any sense of these Markings,
   / Timing Jinma 284, LL380 engine #5
It does "show" but I cannot seem to enlarge it- and it is kinda grainy. Did you take the picture? I need to see all of the gears at the same time to even hazard a guess. Injection pump, cam shaft and crank have to be perfect. Oil pump and hydro pump do not matter.
I double clicked on image at my end and it enlarged before posting if that doesnt work Ill enlarge before downloading
Thanks again Ill try to do more research but Ill Probably go with that.
Thanks for being there
   / Timing Jinma 284, LL380 engine #9
I still cannot open them. When I get back inside I'll re-start Windows 8 and try again.
   / Timing Jinma 284, LL380 engine #10
OK, restarting allowed me to open it. You match the single letters to the double, just as I thought. So for example, the "A" tooth would line right in the middle of the "A" A" teeth on the opposing gear, that gets the single "B" tooth aligned with (in between) the two "B"B". Same with the zeros. That's how it should go.
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
STORAGE FEES (A53426)
JD 1814E LOT IDENTIFIER 265 (A53084)
JD 1814E LOT...
Starcraft Starlite 22ft Travel Trailer (A51694)
Starcraft Starlite...
Genie GTH-844 (A50123)
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
