Oil & Fuel timeing gear setup on a kubota 3 cyl diesel
   / timeing gear setup on a kubota 3 cyl diesel #1
rollpin
PA
this is my first time on i hope iam in the place for this post. i am rebuliding a 3 cyl diesel engine it broke the crankshaft with out warning the con rods were ok . no bearings were spun and no damage to the block i ordered a new crank berrings rings ,ouch! on the price . the question is when i dissembled the engine i could no get All the marks to line up before i dissembled it it appered it was assembled out of time has any one seen this before i instaled a degree unit on the fly wheel to set up timeing need help on this one <font color="brown"> </font> /forums/images/graemlins/crazy.gif
   / timeing gear setup on a kubota 3 cyl diesel #2
I don't think you will find many folks here who have opened their engines up. If you need parts or even some pages from a manual, contact Tractor Smart You will need to supply your model number and they will send you a pdf file with all the info for your tractor. They are great for parts too!
   / timeing gear setup on a kubota 3 cyl diesel #3
I had to put new rods, pistons and rings in my Kubota l2500dt so I know what your talking about on the price thing. It was a little over 700.00 dollars. In my shop I have a manual and can scan and send you a copy of timing proceedure if it would help you............rc
   / timeing gear setup on a kubota 3 cyl diesel #4
Just curious... how many hours are on these engines that you are rebuilding.
The reason that I ask is that I have read in discussions that Kubota diesel engines should run around 8000 hours before rebuild is required.
John
this diesel engine only had 1400 hrs on and had a sudden crank failur problem related to heat treatment of crank shaft i have heard kubotas running in 8000 hr range and longer depending on service and work loads.
   / timeing gear setup on a kubota 3 cyl diesel #6
The engine that I had to work on only had 300 hrs. The previous owner had run it through a pond and took water into the intake and bent two rods. When the shortened rod came down it broke the bottom off of one of the pistons. Figured I might as well put all of the rods rings and pistons in it while I was at it......rc
Steel Work Bench 24" x 60" w/6" Irwin Vise (NO CONTENTS) (A59076)
Steel Work Bench...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2025 GPS Trailers (A56858)
2025 GPS Trailers...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
