Time to sell my JD 2320, Considering a 3039R or 4052R
   / Time to sell my JD 2320, Considering a 3039R or 4052R
Can’t wait! I’m really looking forward to plowing snow. Just ordered my Bluetooth radio and 4x6 speakers! 😎
   / Time to sell my JD 2320, Considering a 3039R or 4052R #13
The 4052R Cab is a great tractor, but overkill for 2+/- acres. It's also a heavy tractor (about 4500 lbs. with the loader...maybe more)
You could handle a 6' RFM easily...maybe a 7 footer.
I used to mow my grass with a Deere 4400 and 6' RFM. The gage wheels on the RFM would tear up the lawn if I turned too sharply or too fast.
A ZTR has a much lower center of gravity...probably safer on the hilly areas (as long as you mow when the grass is dry)
So, my vote is for the 4052 and a ZTR
Where abouts are you in Vermont?
   / Time to sell my JD 2320, Considering a 3039R or 4052R #14
Did it come with that 2 steps entry, or was that an option?
I've got a bad leg, and the 2-step entry might be something I'd be interested in
Did you get the rear wiper kit? Pretty handy if you use a 3PH snow blower...
Very nice. You realize you probably will be the cause of a lack of snow in your area now.
Ain't that the truth! Sit back - turn on the tunes (and heat) and go to town!
I completely agree with you on the tractor for mowing. I worry about compaction and overall weight on the leach field and septic tank. I have 2+/- lawn, but 11 acres of woods/pasture. Tried to have the cake and eat it too - but nope. It looks like a zero turn in my future for sure.
Good looking set-up you have there!!
I believe that step is standard. I build a 4052R, and went back and forth for about a month with the dealer. When it came time to order they could not find anything - told me it would be here in February. I thought about walking to the Kubota dealer (which is fine too), but they ended up finding one in Maine that was a special order, but the guy backed out. So now they have to add the goodies I wanted on it. I did also order the rear wiper.
I am in Springfield Vermont, but also spend a good amount of time in the NEK (Barnet, Ryegate area)
   / Time to sell my JD 2320, Considering a 3039R or 4052R #18
I've got about 9 acres...2 or so is lawn. The remainder is field (3-4 acres) and forest.
The only tasks I use the 4052 (other than field mowing) is snow removal (plowing or blowing) and annual limbs and branch chipping
My ZTR is also a Deere commercial unit (Z920) which I bought used several years ago. IIRC, had around 200 hours on it. It has about 530 hours on it now and has been a great machine. I would not hesitate to buy another used commercial ZTR again. One thing I do recommend is if you buy a used (or new) ZTR, make sure it has a suspension seat. ZTR's are great mowing machines but have a rough ride.
The only issue I've had with this machine (the ZTR) is the PTO switch. I've had to replace it twice. I found a heavier duty (and less expensive) switch on Amazon, IIRC. No problems since...
I've also swapped out the rear turf tires for bar-turfs. Better grip on slopes
I'm in Bethel, work just outside Claremont NH
That's fantastic! Just what I am looking for! I am watching the used market and hope I can find one that someone is unloading this fall.
Sounds like your pretty close to my neck of the woods! I am in Claremont often!
Looks like I will be receiving the tractor Friday. Had to wait for some parts and installation.
I ended up buying a Bluetooth radio and speakers, so I will add that next week. Does anyone know if the harness is already above the headliner?
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
GMC 2500HD 4wd Service Truck (A56435)
GMC 2500HD 4wd...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
LOT: (4) Barrel Hand Pumps (A59076)
LOT: (4) Barrel...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
