Time for wheel spacers on L3800 - advice?
   / Time for wheel spacers on L3800 - advice? #1
ctgoldwing
Platinum Member
Central Connecticut
L3800HST
Our property is on the side of the hill. Some of it is flat but even driving around the house I get a queasy feeling going around one corner - and the grade there doesn't 'look bad'. At first I thought of wheel weights (that much $$$ !!!) and then filled tires. I finally decided to go with spacers on the rear. I'm thinking 3". I really don't beat on the machine so I'm confident I won't destroy the axle.
For those of you who have gone this route can you offer me any guidance? Is 3" appropriate? Is one brand better than another? Anything I should be thinking about (you don't know what you don't know!
Thanks!
   / Time for wheel spacers on L3800 - advice? #2
You can’t go wrong with Richard at Brotek. He will get you just what you need. Good service on a quality product.
   / Time for wheel spacers on L3800 - advice? #3
I have maybe 20-25 degree side hill areas and flat ground...... I put 3 inch spacers on my MF GC 1715 in hopes it felt more stable on side hill work (I know only up and down hill) when at times I had to go "across" the hill .... Seems to make the tractor much more stable and decreases the butt pucker feeling when you have to violate the up/down hill rules.... Granted it's all about slope of hill and how you want to use tractor, but you can not go wrong with adding spacer which makes stance wider charging the center of gravity and makes you feel safer....
I put on the Brotek spacers, could not be easier, and sort of dismissed the argument the extra leverage on axle bearing will cause premature failure..... IF bearing fail from the extra leverage, I will deal with it when or if it happens.... I was dubious of how spacers would help due to the cost of spacers, but it only took a hour or two to realize the dollars spent for the safer feeling that they provided was small price to pay .. The really don't solve all the operating issues on hill sides but helps a lot, ultimately in the end its all with the operator...
Dale
   / Time for wheel spacers on L3800 - advice? #4
I have a CUT JD 3720 with R4s and gave me a tippy feeling even on the flat. I put 4" (2+2) on each rear plus Rimguard fluid to 75% fill in all tires. It made all the difference in the world in stability. Sideways on steep hills still makes me queasy though, but the tractor will slide sideways before it tips over. At least a few times that happened,
   / Time for wheel spacers on L3800 - advice? #5
Go as wide as you can and load tires. Your center of gravity is probably 10” above the height of your rear axle, in the center of your tractor. Standing behind the tractor, you can imagine what angle of tip it takes before this spot passes over the outside edge of your downhill tire and you roll (Not counting dynamic forces).
I have a utility tractor with adjustable rims. When I first got it, it had loaded tires, but I would still feel really queasy and I’d often chicken out on slopes. Can’t remember exactly, but I widened it an additional 7.5” or 10.5”.
Night and day!
Now I feel I could go almost near verticals before it would roll. I know I’ll either chicken out, will get uncomfortable trying to hang on, or it will slide (which can be its own danger) before it’s in any real danger. Of course as one gets more accustomed to that feeling, that can be bad too.
   / Time for wheel spacers on L3800 - advice? #6
For right of way contract mowing I had an L3400 with rear 6” spacers and loaded rears. 80% of the time I was on side hills. I put over 600 hours on it and no issues.
   / Time for wheel spacers on L3800 - advice? #7
It's always a trade off how much to stress components vs how much more stability. I added 2" Brotek spacers and they made a big difference on my L2501, glad I didn't go with 3".
   / Time for wheel spacers on L3800 - advice? #8
I bought a set of used 6” spacers (3” each side) and installed on my L3301. I lived on slopes that were steep enough to be uncomfortable mowing.
The transformation in stability was amazing.
I also adjusted my rims all the way out and my rear tires are filled.
Will your rims adjust out? That’s a free (other than the labor) gain.
   / Time for wheel spacers on L3800 - advice? #9
If you have ag tires, you should be able to adjust the rims to give you additional width (plus a nice savings on not buying spacers). I did this with my L3901, and it made a huge difference in stability. I also filled the tires.
   / Time for wheel spacers on L3800 - advice? #10
Just be careful, as widened (and especially extended) track put significant stress on half-shafts and wheel bearings.
Tractor 3ph and load ability are decreased.
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
Tillit 3 pt Tiller (A50515)
Tillit 3 pt Tiller...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
Wolverine Quick Attach Tree Spade (A50514)
Wolverine Quick...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
