Oil & Fuel Time for the 4110 Oil Change
   / Time for the 4110 Oil Change #11
jeff77indy said:
I'm getting close to the 50 hr. service on my 4110.
Does anyone have an NAPA P/N for the spin on hydraulic filter on the newer 4110's, or am I stuck with a dealer only part? Not sure if my dealer is even still in buisness.
Jeff
Here is the Wix Filter look up website WIX Filters : Filter Look-Up=
They make filters for NAPA
Here is some numbers to save you time:
PART....................................... WIX Part #.............................. NAPA Part #
Fuel Filter....................................... 33263 .....................................3263
Hydraulic Filter (spin on).....................51621 .....................................1621
Oil Filter.......................................... 51381...................................... 1381
Call your dealer before you buy, you would be surprised how competive in price they are !!!!!!!!
   / Time for the 4110 Oil Change #12
Thanks for all the input.
I'll see if my dealer is still going and get what filters I can from them, while it's still under warranty.
I'll check what hyd. fluid I have and any I buy for the TH-500 spec. and use Rotella 15-30, it's worked well for me in my Dodge CTD's.
Jeff
   / Time for the 4110 Oil Change #13
Hi all
two questions for the gang here
First oil change is 50 hr. When is second change?
How do you know if oil is diesel-grade? Last oil I bought was Rotella bought at Tractor Supply. It was 10-40 I believe and said heavy duty I think. I just assumed since oil was with all the other equipment fluids that it was the right stuff. Oil was in 1 gal jug. I'm gonna have to check that oil.
Cheers....Coffeeman
   / Time for the 4110 Oil Change #14
hi coffeeman diesel engine oil usually states on the container that it is for diesel. . . Also look for the API Service donut u want to see CF grade. Ed
   / Time for the 4110 Oil Change #15
Shell Oil Co. has a club for diesels that go 1 million miles and can be confirmed that Rotella was used since the first oil change.:cool: Rotella 15-40 is in all my engines except my 2 cycles. Even my gear boxes run Rotella Gear Oil.
hugs, Brandi
   / Time for the 4110 Oil Change #16
coffeeman said:
Hi all
Cheers....Coffeeman
Coffeeman
After 50 hr (First change) my manual for the 4110 says "change every 100 hrs", Example: 150 hrs, 250 hrs, 350 hrs, etc. etc.etc.
I have gone less hrs, but never more than 100 hrs
Double check your bottle, it will say for diesel engines, API Service CI-4, CH-4,CG-4, CF/SL, SJ on bottle. If it don't ? you are due for an oil change.
A handy way to keep up with your hours for oil changes is to write the hours when the oil was changed on your oil filter with a Sharpie.
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
Kivel Pallet Forks (A57149)
Kivel Pallet Forks...
John Deere 5055E (A53317)
John Deere 5055E...
2348 (A58376)
2348 (A58376)
TANK MANIFOLD (A55745)
Giyi 72" 4-N-1 Bucket (A57149)
Giyi 72" 4-N-1...
