Time for some skid plates
   / Time for some skid plates #1
xrjohndeere
Mo
2021 Kubota L4060 HST
I was using my 342hst the other day moving dirt and cleaning up some under growth brush. I pushed in the rear hydro pedal and it would not come back up. I could not push the other one down either. I could not pop it into neutral. I was on a run away tractor. I didn稚 panic. I throttled down and backed up to a open spot and shut the key off. I locked the brake and lowered the loader and blade. I figured some linkage broke. I looked under the tractor and found a stick was wedged between the two linkages of the hydro pedals preventing them from returning to neutral position. Looking over the under carriage I have decided to build some plates to cover vital stuff underneath and also the fuel tank. Anybody out there make any skid plates for their tractor? Any pics? Ideas? Thanks for any info.
   / Time for some skid plates #2
Full belly works great if you can swing it on your model or as close as you can get. IMG_20201118_055433.jpg
I broke a couple of foot throttle linkages before going into full forestry mode. No problems since..
   / Time for some skid plates #3
your tractor looks more like a Skidder ....:)
just use some 1/4 inch plate use 1/4 X2 for the straps lay out how you want it all to bolt to the tractor
then come back and weld your straps to the plate steel , roud off and edges so they dont catch and dig
either in the debri field or you split your head on it when your under it ..
Jake
   / Time for some skid plates #4
I have a subframe mount for my backhoe that replaced the FEL support arms that ran from my rear axle to the loader brackets. The new subframe mount is more like a 'T' (upside down) with 3/8in steel vs the old square stock that was factory. This makes an excellent shelf for expanded or sheet metal. I've been planning on bolting something to this 'shelf' to act as a skid plate for a while, just havent gotten to it. I was thinking of expanded metal because that way I can easily tell if there is a leak or something, while offering protection. Granted, the protection offered by expanded is not as good as sheet steel, but better than nothing.
Maybe consider fabricating new loader support arms, like an upside down 'T' that will serve as the FEL supports and a shelf for a skid plate.
   / Time for some skid plates #5
Hello,
the expanded metal is like pissing in the wind !!
if you going to put the time in to build a shield/guard then do it right
the first time and you wont have to go back and do it a second time ,
on a guard it can be drilled if needed ,, then if there is any leaks that
may arise you shoud be able to see drips ,,, then you will know you
have a problem ,,
Jake
   / Time for some skid plates #7
Not real pretty, but nothing get's past it.
If also makes for a handy chain box. (pic on rt. circled)
   / Time for some skid plates #9
Thanks Red, as you well know, there's not much to attach to under there. Got any pics of your set up? I like to see how others handle this.:thumbsup:
That is exactly what I am thinking. Nice work.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A51219)
2016 INTERNATIONAL...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
2005 Mercedes-Benz C-Class Sedan (A50324)
2005 Mercedes-Benz...
1264 (A50490)
1264 (A50490)
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
