Time for a new battery
   / Time for a new battery #11
JB4310 said:
Yeah, it's getting confusing, they couldn't help me at Napa, might just go to Deere to be sure. Thanks all.
JB, you might want to look at this one. I posted this before when this issue was addressed and just checked, looks like it's still available:
Adventure Power UB12550 (Group 22NF) Battery - Group 30H Batteries
Resists shocks and vibrations
Will not leak, even if mounted upside down
AGM design (Absorbed glass mat) SLA (sealed lead acid) design
55 AH rating
670 Cold Cranking Amps
850 Marine Cranking Amps
It is the correct group size but the hold down might be different so you might need to implement a bracket mod... I've seen others use a heavy rubber bungy cord or a few simple automotive style brackets/rods availabe at any Kragens, etc. It's a little on the expensive side but if you compare the specs, I think you'll be hard pressed to find one better spec'ed or featured.
55 AH rating
The length and width are right on, as long as it has the tabs sticking out on the lower sides it would drop right in, don't know if I want to spend that much though, if I had a greater electric load like an inverter or a lot more acs lights I'd go for it, Deere gets $90. now for the strong box.
To follow up, I went ahead and got the Deere Strong Box for $87.+ tax, they said 3-4 years is all I should expect from this battery. The only problem is when I got it home, 2 of the cells were bone dry and since I know they had it on a charger so it would be ready to go, I didn't think that was a good condition and went back to get another one, they replaced it no problem, dealer is only about 10 miles away so I wasn't upset about the ordeal.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Takeuchi TL8R2 (A47477)
Takeuchi TL8R2...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
T/A Towable Diesel Generator (A55787)
T/A Towable Diesel...
