Timberwolf tw3 n tw hd pto log splitter
   / Timberwolf tw3 n tw hd pto log splitter #31
Anyone know if the tw3 is just too much for the dk40 with 32.5 hp pto 41 engine
   / Timberwolf tw3 n tw hd pto log splitter #33
I have the TW3HD, and it needs more than 16 to have full power... But 32 PTO hp tractor should run it just fine... I assure you, 16hp isn't going to cut it!! I run mine "most of the time" on my 30 PTO Deutz and with really tough crotches, the governor kicks in a bit, but with everything else it doesn't even slow down one bit...
My TW3HD model is one of my best buys ever!!
SR
   / Timberwolf tw3 n tw hd pto log splitter #34
SR
HE asked about the TW3.
According to TW, The TW3HD requires 30HP
   / Timberwolf tw3 n tw hd pto log splitter #35
That's odd, the title of this thread is
SO, I thought he was asking about BOTH! I guess that hd there, meant something else?
SR
   / Timberwolf tw3 n tw hd pto log splitter #36
SR
My response was to balreadysaid that jumped in here on the 4th page of this thread.
Ur better off with a stand alone if u have 1 tractor for the price of tw3 or tw3hd, very nice quality splitter but american cls is just as good n u can use the loader as a lift for the logs, I don't werk for american, but do like good quality equipment.
   / Timberwolf tw3 n tw hd pto log splitter #38
I've run a tw3 on a kubota b3030 for years ~23 pto hp. It has never stalled the tractor. I've split up to 30" oak. The tw3 HD has a larger diameter cylinder. The cycle time is well faster than I can keep up with. Being a single speed pump, it never slows down. Weight is a concern with birth units, even the non HD is HEAVY. Either of these units will outperform all but the most serious standalone units. The HD has a slower cycle time due to the larger cylinder
   / Timberwolf tw3 n tw hd pto log splitter #39
All true, the HD also is built stronger all around and comes with the slip on 4-way wedge... (that I wouldn't want to be without!!)
The CLS is NOT built as strongly as the TW3HD, maybe not important to some folks, but it sure is to me, as I'm running some serous crotch wood through the 4-way time after time!
Everything goes right through it, i've not even come close to stopping it!
I use my loader to hold my firewood logs over my wagon, and they are cut to length right there,
Then I can roll those huge chunks right off the wagon onto the beam of my splitter,
It works perfectly, and saves my back from beginning to end!
SR
I have the cls super log splitter priced the same as tw2 hd= tw3hd it's heavier than the tw2 hd n they use a 4"x6" tubular frame which is stronger than I beam frame with 6 sec cycle time, I'm lucky to have a american n timberwolf dealer near by n was able to compare the 2, it was a tuff decision I went with the american cause I got more for the buck n high quality splitter to boot, it's more comparible to a tw5 fc
gravely riding mower (A55758)
gravely riding...
CATERPILLAR 308E2 CR EXCAVATOR (A52709)
CATERPILLAR 308E2...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
TANK MANIFOLD (A55745)
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
