TimberAx Or Carbide Cutter G2
   / TimberAx Or Carbide Cutter G2 #1
dunebuggy55
Hello Mulchers, I am thinking about getting into this buisness .I currently work for a excavating contractor here in PA.I am a heavy equipment operator. I run a 257B just about every day.I have been reading all of your guys post on different types of mulchers. I would like to Know what you think is better the Timber Ax Or the G2.What are the Pros and Cons of each.Will a 257 be enough machine to handle either of these heads. Overheating problems or any thing else i should be concerned with. Thanks , any input would be greatly appreciated
   / TimberAx Or Carbide Cutter G2 #2
Can be done but would look into bigger machine...Can get by on 257B must be High Flow model and you would be limited to the T.Ax due to flow requirements of the G2.
   / TimberAx Or Carbide Cutter G2 #3
Nobody knows the 257 better than Scott for mulching!:D
I have both and need {want} bigger everyday. Good Luck
2020 CHEVROLET SILVERADO TRUCK (A51406)
2020 CHEVROLET...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2012 Ford F-350 Omaha Service Truck (A51692)
2012 Ford F-350...
