TimberAx Or Carbide Cutter G2
   / TimberAx Or Carbide Cutter G2 #1
dunebuggy55
Hello Mulchers, I am thinking about getting into this buisness .I currently work for a excavating contractor here in PA.I am a heavy equipment operator. I run a 257B just about every day.I have been reading all of your guys post on different types of mulchers. I would like to Know what you think is better the Timber Ax Or the G2.What are the Pros and Cons of each.Will a 257 be enough machine to handle either of these heads. Overheating problems or any thing else i should be concerned with. Thanks , any input would be greatly appreciated
   / TimberAx Or Carbide Cutter G2 #2
Can be done but would look into bigger machine...Can get by on 257B must be High Flow model and you would be limited to the T.Ax due to flow requirements of the G2.
   / TimberAx Or Carbide Cutter G2 #3
Nobody knows the 257 better than Scott for mulching!:D
I have both and need {want} bigger everyday. Good Luck
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2014 Stoughton 28ft Dry Van Trailer (A51692)
2014 Stoughton...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
2003 Ford F-250 Knapheide Service Truck (A51692)
2003 Ford F-250...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
