timber ax
/ timber ax #1
central virginia
2007 T300
I have a 2007 timber ax. I am seriously considering selling it. and buying something different. I just finished a 3 acre clearing job. mostly pines in the 6-8 inch range. It seemed to struggle a bit. Maybe it was my technique. Im not sure. I was just a little disappointed.
/ timber ax #2
I used to run an ASV RC100 with Loftness Timberax on a daily basis...I am no longer invloved in the Clearing business but am working as a sales associate for DENIS CIMAF...I know what you mean about the Timberax..it is great in small vegetation up to about 2-3inches but the productivity drops off dramatically in brush any bigger...
/ timber ax #3
Id guess you need more HP. I used the 140HP supertrak, it went thru about anything. ive also used 90hp machines that struggled at 4 or so inches
/ timber ax #4
You might want to make sure the Hydraulic output is high enough to operate the timber ax. I run a Fecon cutting head and was having trouble, come to find out it was my machine. It wasnt putting out factory specs.
/ timber ax #5
I run loftness heads now....and rand the timber axe for a little while. It can be hard to mnage, but it does a good clean up job. The quickaxe however, runs the same direction as a carbide cutter, and is MUCH more efficient than
the timber axe.
Still not as fast as a Cimaf, but $10,000 less (Sorry Robbie). I love my quickaxe, and its the only reason that i am still in business. With the economy
the way it is, i needed to drop my price per acre. With this head, i can do much more work per day than before.
Just my two cents.......
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
2012 MACK GRANITE-GU713 (INOPERABLE) (A65643)
2012 MACK...
4021 (A59228)
4021 (A59228)
(2) Wood Pellet Grills (A64127)
(2) Wood Pellet...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
3 Point Hoist (A62613)
