Tilting a rear box blade
   / Tilting a rear box blade #1
glsche
Mountainair, NM
John Deere 3032E
New to TBN and this is my first post. I have a JD 3032e with a BB2060 box blade. Tilting the box blade with the hex adjustment shaft on the left side of the 3-pt hitch is very difficult requiring the use of a large crescent wrench and lots of muscle. This is true whether the blade is on the ground or off. I greased the threads and tried greasing the adjustment shaft using the grease fitting on the shaft (maybe too much) and had to unscrew the plastic cap on the opposite side of the grease fitting to relieve the pressure.....most of the grease I put in came squirting out. Oooops....live & learn....this is my first CUT. Once that mess was cleaned up I put the plastic screw cap back on and tried adjusting it again. Better, but still requires the use of the large crescent wrench. I've seen videos of guys adjusting the tilt by-hand only...no tools. Is something not right with my adjustment rod, etc or am I doing something wrong? The tractor is a 2010 with only 200 hours. Any suggestions? Thanks!
   / Tilting a rear box blade #2
I have found that if you raise and lower your 3 pt while applying pressure to the turn buckle you will find a spot where it is easy to turn. After a few turns it gets difficult so just raise/lower agin and find that sweet spot again.
Sent from my iPad using TractorByNet
   / Tilting a rear box blade #3
That is the trick and the same works for the toplink too.
   / Tilting a rear box blade #4
By the way, Welcome to TBN. The difficulty in turning the top or bottom links also relates directly to the weight of the implement attached. The box blade, being quite heavy, can cause the turn buckles to bind up fairly tight. Green Frog has the answer.
   / Tilting a rear box blade #5
Like the others said there's a spot where its "relaxed" .
Lower the implement to where it just touches the ground and watch your lift arms just past that point you will have some free play, you can also tell your at the right spot by wiggling the lift arm. When it not under tension it easy to more around on the pins. And if you adjustable link is on the left and your lift lever is on the right like you decribe its a two person job or a bunch of walking back and forth. On my kubotas the adj link and hydros are on the right and reachable while standing behind the tractor (actually that only applies to one of my kubotas the other has a hyd side link)
Thanks to all of you that replied so quickly. I'll try finding the sweet-spot by raising/lower the 3pt hitch. BTW - I misspoke....the turnbuckle (thanks for clarifying what that hex-shaped adjustable shaft is called) and the lift lever are both on the right side of the tractor so making adjustments to both should be pretty easy. I'll let you know how it goes. Thanks again!
glsche
Bandaidmd - I love your "it's OK to say Merry Christmas to me" plate!!! Dito. And Happy Easter to you as well!
   / Tilting a rear box blade #8
Hydraulic top link is what you need. Makes using a box blade a joy.
   / Tilting a rear box blade #9
Even better with hydraulic side link and hydraulic rippers!
I tried taking the stress off the side link by just slightly lowering the bb to the ground but that still didn't make adjusting the turnbuckle any easier. When I have a few minutes I think I'll try removing the bb from the 3pt hitch, disconnecting the side link from the drawbar and see if the turnbuckle still is difficult to turn. If so, I'll completely unthread it from the side link, clean and degrease and reassemble. Good thing this kind of "investigative maintenance" is enjoyable!
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
WARREN POWER SYSTEMS  100KW GENERATOR (A50854)
WARREN POWER...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
