glsche
New to TBN and this is my first post. I have a JD 3032e with a BB2060 box blade. Tilting the box blade with the hex adjustment shaft on the left side of the 3-pt hitch is very difficult requiring the use of a large crescent wrench and lots of muscle. This is true whether the blade is on the ground or off. I greased the threads and tried greasing the adjustment shaft using the grease fitting on the shaft (maybe too much) and had to unscrew the plastic cap on the opposite side of the grease fitting to relieve the pressure.....most of the grease I put in came squirting out. Oooops....live & learn....this is my first CUT. Once that mess was cleaned up I put the plastic screw cap back on and tried adjusting it again. Better, but still requires the use of the large crescent wrench. I've seen videos of guys adjusting the tilt by-hand only...no tools. Is something not right with my adjustment rod, etc or am I doing something wrong? The tractor is a 2010 with only 200 hours. Any suggestions? Thanks!
