Tilt stopped working.
   / Tilt stopped working. #1
duckhunter27
Dannebrog , NE
Bobcat CT 335
Thought i would share this with everyone. I was pileling ceder trees and it was very thick and alot of brush anyhow i went to dump trees in to pile and my forks would not tilt but about 2 inches. I got ceders off and backed up and checked tractor over my loader would go up and down no problem but my tilt would only go about 2 in either way. what i found was that one of the quick couplers under the tractor to the loader had came undone was hard to see but one coupler was about a 1/4 inch farther out then the rest. Released all pressure and poped it back in worked fine.
   / Tilt stopped working. #2
This is a very common issue in the compact tractor/loader industry.
Even if it doesn't look like the are disconnected. We always tell our customers to disconnect and reconnect just to make sure.:thumbsup:
I felt lucky to find the problem so fast and just wanted to pass alone to anyone else working it thick bruch etc.
   / Tilt stopped working. #4
I had the verry same thing after washing my N H. I use a soft brissol brush on a pole. seems Ihit one quick connect an had same problem. I think I asked here an got back on track tks. to quick reply from a fellow.
Army Grunt
4' x 6' Tilt Trailer (A50515)
4' x 6' Tilt...
New Calf Hut (A50515)
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
White 6065 Tractor (RIDE AND DRIVE) (A50774)
White 6065 Tractor...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
