Tiller Tiller vs. Harrow or what else?
   / Tiller vs. Harrow or what else? #1
daBear
Brandon, MS
Kubota L2800
I am a tractor new guy. I have about two acres around my house with grass, the rest is wooded. This year we were able to get a fair stand of common Bermuda going, but it will need minor fill in and leveling next spring. I have just finished applying rye grass to hold the dirt as necessary this winter.
My question is what attachment is best to use next fall. I do not want to just pulverize the whole two acres with a tiller. A neighbor just brought his 70hp Kubota (M7040)over with a 5' Woods tiller and hit some hard and bare spots for me and that is an awesome piece of equipment but the tiller gets everything it it's path. Maybe a drag harrow or something like that will break the crust up without destroying the first years grass. Then I can over seed with Bermuda, fertilize and water. What do y'all recommend for an attachment?
   / Tiller vs. Harrow or what else? #2
Bear your right that a tiller will take everything in its path so that is not the tool for over seeding. Bermuda is a running grass that takes a couple of years to establish so you may need nothing but time if you got a good starting stand. Being a running grass I would think that a drag harrow would tend to tear it up a bit more than is desirable. I use a core aerator on our clay to get water and fertilizer to the root system. That works well when I over seed my fescue and allows the seed to collect in holes left where the plugs are pulled out. The correct tool is a vericutter which cuts slits for the seed to collect in or a seed drill which cuts the slits, drops the seed and then covers the slits. Both are pretty expensive pieces of equipment for the non-professional.
MarkV
   / Tiller vs. Harrow or what else? #3
If you have Bermuda grass you can not cut it and destroy it. If you have Bermuda grass in a field if it is 5 ft and you cut it and drag it you will have 20 ft the next year.If you cut around the Bermuda and drag it them put more fertilize on . It will spread like wild fire.next spring were he did the bear spots it will loosen the ground up and the Bermuda grass will cover it up if you fertilize it.
Thanks, both replies make sense to me. I am thinking about a small chain harrow with 3 pt frame so you can move it from spot to spot. Seems like that will be a good tool to aerate the grass and loosen the soil every once in a while.
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2014 Jeep Compass 4x4 SUV (A55853)
2014 Jeep Compass...
2005 Interstate 7x14 Trailer (A55973)
2005 Interstate...
2018 Ford F150 (A55973)
2018 Ford F150...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
