Tiller stops every two minutes
   / Tiller stops every two minutes #1
RSKY
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
I have a Troy Bilt tiller that has never given me a problem that I didn't cause with neglect or stupidity. BUT now it is doing something weird. The Briggs and Stratton engine cranks, and I till for about 1-1/2 to 2 minutes and the engine sputters and dies. I let it sit for about a minute, put the choke on a little more than half and it cranks first pull and runs for another minute and a half to two minutes.
Any ideas?
RSKY
   / Tiller stops every two minutes #2
Does this model have a carb mounted below the tank or on top of the tank?
If carb below tank I would suspect a fuel flow issue between fuel tank and carb.
If tank mounted not sure but possible rubber diaphragm fuel pump is stretched or has pinhole causing it to pump for a little then quit.
   / Tiller stops every two minutes #4
Still sounds like fuel starvation. Its running out what's in the float bowl then quits.
Pull off the fuel line between the fuel tank and carburetor and see if you have a good steady fuel flow. (is the fuel tank plugged ? Plugged filter ? Fuel tank vent tube ? Float or needle valve sticking ?)
   / Tiller stops every two minutes #5
There are decades of Briggs and Troy tillers. A model and type number from the engine would be helpful. The fuel cap or carb bowl not venting would be a good guess. Or a float valve that can't fill fast enough due to a swollen seat.
   / Tiller stops every two minutes #6
Had similar problem with plate compactor, check vent hole in fuel cap.
   / Tiller stops every two minutes #7
These carbs need cleaning every year with the **** ethanol additives. Guarantee that the ethanol is gumming up the needle passage. I bet it's got a carb where the needle is attached to the float and it's gummed up. I have to clean or rebuild nearly every small engine carb I have every year. It really doesn't matter if you use fuel stabilizer or not. Running empty before storage is your best bet.
   / Tiller stops every two minutes #8
Does your model vent through the gas cap?? Try leaving the cap loose to see if that makes any difference. Dirt buildup or even spider webs in a gas cap vent can cause that problem.
It isn't the fuel cap, that was my first guess and I ran it with cap off and still had the same problem. I am not for sure if the gas left in it over the winter was ethanol free or not. I usually burn only the ethanol free in my small engines but may have run short last year and used regular instead of driving 25-miles to get the alcohol free. Gonna run tank dry and fill with pure gas with some Gumout or something in it and try that first. Keep the ideas coming.
RSKY
   / Tiller stops every two minutes #10
If it has a fuel filter or screen in the bottom of the tank check those.
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
PREVIEW DATES AND TIMES (A54865)
PREVIEW DATES AND...
