tiller sizing, remove row of cutters?
   / tiller sizing, remove row of cutters? #1
koshari
Kioti ck35 , Deutz agrolux 4.80e, Deutz Agrotron 6.00 TT, Kobelco sk30ur excavator.
There is a tiller going locally which is not to far to go and is pretty well priced but its a 7 row, we have a 35hp which i think will be marginal, seller was running it behind a 45. could i disconnect the 2 outer tiller blades therefore making it a 5 row tiller to lighten the load on the pto?
   / tiller sizing, remove row of cutters? #2
You can but the rotor without tines will interfere with depth control and the unprotected rotor flanges will wear rapidly and soon will not be able to accept tines should you decide to reinstall them. If you have a hydrostatic transmission try tilling with all the tines.
   / tiller sizing, remove row of cutters? #3
I run a 6 ft tiller (seven sets of tines, but 6 on a node -- not quite sure what you mean by rows) behind a Kubota L3400 (geared). No problem in worked soil, will require two or three passes in established sod. Our soil is mostly clay, with a very shallow organic layer.
   / tiller sizing, remove row of cutters? #4
I have removed tines with no problems noted.
2010 FORD F-150 (A58214)
2010 FORD F-150...
flooring (A55758)
flooring (A55758)
Bucket (A55973)
Bucket (A55973)
Case skid steer wheels and tires (A56435)
Case skid steer...
2021 Kubota SVL75-2 Track Loader (A56436)
2021 Kubota...
2017 Ford (A55973)
2017 Ford (A55973)
