Tiller Tiller Size?
   / Tiller Size? #11
How much trouble will it be to plant a garden in those tractor tracks? It's better than no tiller, but personally I wouldn't buy one that wouldn't cover my tracks on at least one side. Of course, I certainly understand about the money. When I traded my B7100 for the B2710, I offset the tiller to cover the track on one side because I just couldn't see spending enough to buy a wider tiller, but if I hadn't had a tiller already and was going to buy one, I wouldn't consider anything that wouldn't cover both tracks while it's centered.
   / Tiller Size? #12
We have turf tires and found that the tiller not covering either rear tire to be a HUGE pain. Even when we moved the tires in all the way and shifted the tiller we couldn't completely cover either tire and the tiller wanted to till at an angle / because the tires were rolling back and forth over the edge between tilled and untilled ground.
We have the same problem with the WheelHorse C-16 and it's 36" forward rotation tiller, you just can't cover the wheels completely but becausee neither rear wheel sticks out more than 1" past the tiller tines, it is managable.
The Kubota ~48" tiller we had was also a forward rotation tiller and it constantly tried to push the tractor forward and shook violently over hard unbroken ground. This is even with controlling the digging depth and it left clumps behind, not a nice smooth planting bed.
The new 60" reverse rotation tiller has similar tine counts and about the same number of rows for the width but doesn't shake the tractor and leaves a much more even bed without the larger clumps. It is also much easier to control ground speed because the tiller tries to hold back on the tractor and not push it forward (no forward/brake/forward pedal gymnastics).
The least expensive new tiller I could find in the area for a 5' model was $1395, I paid just under $2k for the LP with more tines, one more row of tines and reverse rotation and a 5 year gearbox warranty. For our situation, it was money well spent. We had looked at rear-tine walk-behinds and paid LESS for this PTO tiller than for a 36" rear-tine walker!
   / Tiller Size?
You've convinced me to go with a 6' tiller - and hopefully be able to find a reverse at a reasonable price. Once again, you guys are a wealth of information, many thanks.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2010 Cadillac SRX SUV (A56859)
2010 Cadillac SRX...
12' CONTAINER (A52706)
2014 RAM 2500 (A58214)
Pnuematic Transfer Pump on Rolling Cart (A59076)
Pnuematic Transfer...
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
