Tiller PTO shaft replacement
   / Tiller PTO shaft replacement #1
kenr74
Amity, OR
Yanmar 1610D
Need some advice on my PTO shaft for my tiller. I was out tilling the garden and heard this thing come apart. Never really looked at it before but it appears to be beat up pretty bad. Maybe it can be repaired?
I found repair parts(new yoke and u joint) on Hoye but for the price(about $120) was thinking about just buying a whole new unit.
Do they make them this short. Seems like I need one around 16"-18" and I can't find anything even close to that short.
   / Tiller PTO shaft replacement #2
I do not have any parts for those tiller shafts. I'm not sure what you found on our site but it will not work with your shaft.
I do have a bunch of used tiller shafts and parts coming in pretty soon though and might have something there that will help. A local driveline shop could probably build you a shaft that would work also.
   / Tiller PTO shaft replacement #4
It looks similar but that is for the 4wd shaft of a YM186D. It does not have the same splines or u-joint dimensions.
   / Tiller PTO shaft replacement #5
What brand and model tiller do you have. My Yanmar tiller has a 6 splined shaft. How many splines and what size is your shaft? PTO Yokes & Repair Kits
It is a Yanmar 1503 tiller. I looked at just the yoke but I need the female side of the driveshaft not the yoke that attaches to the tiller. It is a 16 spline and about 1 1/8". I haven't been able to find just that piece.
   / Tiller PTO shaft replacement #7
I have 5 (almost new) yanmar tiller PTO shafts both ends = male & female end. They have so many splines because they are for high speed tilling.
I was doing a final cleaning out the shop and buela !:D
Please contact me thru TBN.
Thanks Ernie
I went ahead and just picked up a longer unit that I will cut down. Fits up fine and now I can get off the shelf parts for it locally.
   / Tiller PTO shaft replacement #9
Thanks Ernie
Gotta be somewhere in the Bahamas, probably not too far from Ft. Lauderdale.
   / Tiller PTO shaft replacement #10
They dress like American Gothic in the Bahamas?
I expected Ernie would wear more like Fyre Festival attire.
:D
16FT Flatbed Trailer (A51573)
16FT Flatbed...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
Wheels and Tires for Four-Wheeler (A51573)
Wheels and Tires...
FRONTIER LP2196 LOT NUMBER 113 (A53084)
FRONTIER LP2196...
WEILER B670 FELLER BUNCHER (A51246)
WEILER B670 FELLER...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A51572)
2021 Big Tex...
