Tiller Tiller on the tractor crooked with tractor ?
   / Tiller on the tractor crooked with tractor ? #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
The right end of the tiller is 1.5 to 2 inches closer to the rear tire than the left end.
How do I square it up so the tiller runs straight across the back of the tractor instead of at an angle?
   / Tiller on the tractor crooked with tractor ? #2
Mine had the same problem. I moved the adjustment on the 3 point arms until it was strait.
   / Tiller on the tractor crooked with tractor ? #3
yes same here just 1.5" or so. adjust the "stabilizers" the part nearest each tire (at least on my kioti ck30) to move in the correct direction. also if there is a height adjustment on one side of the 3-pt hitch could adjust it for up and down
mike
mike
Are you talking about moving the 2 arms by adjusting the check chains?
Am I on the right track here or have I got it all wrong
   / Tiller on the tractor crooked with tractor ? #5
LBrown59 said:
Are you talking about moving the 2 arms by adjusting the check chains??
Thats what I meant. Your on the right track.
Thanks ;
Just wanted to check with the fellows on the board just to make sure before going ahead on my own and maybe screwing things up by doing the wrong thing.
I have little to no experience with a 3 point hitch.
Just got done squaring the tiller up with the tractor .
Looks good.
Thanks for your help everyone.
2014 Ford F150 (A55973)
2014 Ford F150...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2013 Peterbilt 367 (A55973)
2013 Peterbilt 367...
