Tiller Tiller Mod
   / Tiller Mod
"S" tine shank JD part # N185521 $22.25
"Clamp" JD part # N185522 $4.05
This shank and clamp will fit 3x3x1/4 tube steel
You can look these up, see the parts drawings and order online @ JD parts just register it is free. It is the same drawings that the dealer has.
   / Tiller Mod #33
</font><font color="blue" class="small">( "S" tine shank JD part # N185521 $22.25
You can look these up, see the parts drawings and order online @ JD parts just register it is free. It is the same drawings that the dealer has.)</font>
Hmm. Significantly cheaper at Agri-Supply.
S-tine #27804 32"x10" @ $5.70 each
heavy duty S-tine 42"x12" @ $14.72 each
3x3 clamp #29757 @ $1.99 each
Bedding sweeps ranging from 10" to 24" prices are $3.71 to $13.77 each
Agri-Supply catalog - see page 20
   / Tiller Mod #34
This project certainly got my interest. I printed out the Agri-Supply catalog on page 20 and was wondering how I should go about determining which bedding sweeps to order. Any suggestions?
   / Tiller Mod #35
I have no idea. I am not a farmer or gardener, yet. However, I did purchase one s-tine and one clamp that I will be using to prototype up something for myself later this spring.
   / Tiller Mod #36
Wall could answer that, as is it looks like 12-16 inch from the pictures.
   / Tiller Mod #37
I'm gona have to build one, has to save a ton of time. What if one was to fix the shovels to a rotating shaft at the rear and add a hyd cyl on a crank arm. One end of the cyl would attach to the back side of the top link, the other to the crank arm keyed to a shaft with the shovels fixed to the rotating shaft. Think you would be able to raise and lower the shovels from a remote on the tractor??? You could do your rough passes with the tiller first and tilt and the shovel raised. Tilt the shovels down when the soil is ready and cut your rows. More trouble than it's worth???
Chris
   / Tiller Mod #38
Wall, I followed your lead and made up a similar setup.
   / Tiller Mod #39
another view
   / Tiller Mod #40
the results
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A57880)
2015 FREIGHTLINER...
Zero Turn Mower (A55853)
Zero Turn Mower...
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
