Tiller gear oil
   / Tiller gear oil #1
Ffterman
Ferris, Tx
Massey Ferguson 1736HST
I recently bought a Land Pride RGR 1266 tiller. After using it a total of 6 hours over several days I noticed the oil on the sight glass on the side gear box is milky in color. Is this normal for a tiller?
   / Tiller gear oil #2
I don't think so. Mine is Bush Hog brand & no sight glass - just pull the lower bolt & see if oil comes out.... But what comes out looks like new oil - not milky. Milky oil usually makes me think of water in it.....
   / Tiller gear oil
Yeah I was thinking the same thing. Now to try and figure out how water got in the gear box so this doesn’t happen again. Thank you
Al
   / Tiller gear oil #4
Al
Water gets into gearboxes due to several things. One, leaving a piece of equipment outside in the elements and rain or snow leaks past the rubber grommets of a gear selector/shifter, and the other most common issue is water can collect due to condensation, especially during major temperature swings. Change the fluid asap and then change it every couple of years or sooner if it gets cloudy earlier. Dutchy
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
2017 S-60X MANLIFT (A51246)
2017 S-60X MANLIFT...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
