tiller from Kubota B-21 on my JD2210
   / tiller from Kubota B-21 on my JD2210 #1
gsk99
Has anyone ever hooked something like a tiller from a Kubota B-21 to a JD2210? I can get a hold of one but I don't know if the PTO shaft is going to be the right length. Before I haul my tractor over there or the tiller here to try it I'd like to get any comments from this forum.
   / tiller from Kubota B-21 on my JD2210 #2
Tiller for a B-21 is not specific to that model tractor. Should work on your JD 2210. Be sure to check PTO shaft length to make sure it is not bottoming out. You may want to measure distance from 3PH balls to PTO shaft on both tractors.
   / tiller from Kubota B-21 on my JD2210 #3
Even if the PTO shaft isn't long enough, all of my implements have a 3rd party shaft so I'd guess that your tiller does too. This means that you should be able to just replace the shaft with a longer one but keep the tiller.
   / tiller from Kubota B-21 on my JD2210 #4
I bought a pto driven trac vac from a guy that had it on a Kubota BX and the shaft was 3" shorter then what I needed for my 2210.
2020 Case TV450B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TV450B...
CUSHMAN HAULER PRO GAS GOLF CART (A51243)
CUSHMAN HAULER PRO...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
